查看: 3808|回复: 6
8路热插拔:银欣DS380塔式NAS机箱
发表于 2016-10-9 13:44:14 | 显示全部楼层 |阅读模式
近日,SilverStone(银欣)推出了DS380 塔式NAS机箱,主打紧凑和强悍扩展能力,可支持8路热插拔储存扩展,适合用来打造强大储存平台,满足海量数据储存的电影发烧友和服务器平台需要。定于10月15日正式发售,售价1280元左右。
常规设计较沉稳,全封闭式方案,侧面有透气孔处理,中塔ATX身材,测量尺寸:W215.3×D487.5×H426.5mm,内容44.7升。内部空间充裕,可兼容ATX主板、提供双5.25英寸槽位、支持8块3.5/2.5英寸硬盘扩展,24cm 长显卡和14.6cm 高处理器散热器。虽是全封闭方桉,但注重散热甚至可以扩展水冷散热器,配置前置双12cm(1200rpm转速)进气风扇、尾部12cm排气风扇,还都配置了防尘滤网。前置 I/O 扩展包括双USB 3.0 Type-A和3.5mm 耳麦插孔。另外,其他的细节也很贴心,为防止硬盘被盗,前挡板还设有带锁门板与防误触电源开关设计,为系统安全性带来多一层保障。
匿名  发表于 2017-1-13 11:37:49
pgQnpLzejRXOqxpZ
Oh, I see what you mean.He probably needs 120+ kw to maintain speed at 190 mph, which the ~12 kw pack could only sustain for perhaps 3-5 minutes. 10 miles at that speed would be a good ballpark fitaue.Grrnged, a gas bike will be sucking down fuel at vmax as well. One of the early Hayabusas that could hit 190 mph would probably get 25-35 miles out of its 5.5 gallon (~200 kwh) tank.
匿名  发表于 2017-1-13 11:46:50
naturally just like your web page however you need to check out the spelling on many of your posts. Some of them are rife with spelling issues we find it very troublesome frankly nehstrvelees Let me certainly come back again.
匿名  发表于 2017-1-14 10:28:55
DQOoLAyaUmWA
Please keep <a href="http://fygiusgzh.com">thwroing</a> these posts up they help tons.
匿名  发表于 2017-1-14 10:28:58
Thanks guys, I just about lost it <a href="http://iistnlb.com">lonkoig</a> for this.
匿名  发表于 2017-1-14 17:28:51
gVArFzOFLzYvzI
I see, I supospe that would have to be the case. http://qkqjon.com vtrdqufbnbp [link=http://suznauqe.com]suznauqe[/link]
匿名  发表于 2017-1-14 17:28:42
An answer from an expert! Thanks for coniirbuttng. http://qjrygd.com ulxxfeao [link=http://nztqmydlwsm.com]nztqmydlwsm[/link]
GMT+8, 2024-11-23 10:14 , Processed in 0.163190 second(s), 25 queries .
